Routing Configurations Not Appearing
I am piping a simple water system using various 90 elbows and 2"-3" pipe.  In the Routing Properties menu, it prompts me for the pipe part file in the design library.  However, when I specify the pipe.sldprt file a warning menu pops us and says "No Valid Configuration Could Be Found for This Pipe".  Therefore, I can't choose the size or schedule that I need.  The strange thing is that some elbows that I've already inserted into the assembly allows me to specify the configuration, but any new elbows do not.
RE: Routing Configurations Not Appearing
Check to make sure you r Add-in is turned on and make sure that the in the design library under the file locaitons or Tools Options\ System Options you have the path setup for the routing the folder.
Also try opening the pipe.sldprt and make sure there are configurations in it. If not that is your problem the file maybe corrupt, or someone saved over top the file and it was replaced with a file that has no Configs.
You will have to get the file from a Colleague or your VAR
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
