hatching text
hatching text
Hi guys, I'm drawing some panels, which need text silk-screened on them, I've drawn the text as extruded features on the sheet metal. Now I'm drawing the art work page, and to highlight what needs silk-screening, I'm trying to hatch the text with a solid pattern, which works, except that every successive letter I select, takes progressively longer to process, Its at the point where it's taking near 15 seconds from selecting the region, to the region hatching, and it’s getting progressively worse.
Is there a way to select several regions at once, or otherwise remedy the situation? Has anyone else had this problem?
Any help is appreciated, thanks,
Nick
Nick
RE: hatching text
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
RE: hatching text
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
RE: hatching text
We also design sheet metal parts that require silk-screening. What we have found that works best is that we just type the text in the drawing where needed. Also we create sketch blocks for various symbols that we use on our drawings.
All or most of our silk-screeners require an Adobe Illustrator file. So we create the final artwork in that program. The Text and symbols on the drawing are just sort of a reference to the adobe Illustrator file.
We even tried to embed the Illustrator file into the drawing document but it trasfers over really messed up. This was the best and easiest way we have found to work around this kind of issue.
If anyone else has better ways of doing this I would be interested to know also.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
http://solidworks.carbonmade.com/
Solidworks 2006 SP4.0
RE: hatching text
thanks,
nick
