ANSYS LS-DYNA
ANSYS LS-DYNA
I'm a new user of ANSYS LS_DYNA, I'm trying to model a hammer impact in the surface of steel sample. I do not use the GUI of ANSYS, I prefer to write a scipt that I load it in ANSYS for execution. No error message comes out in the end of the simulation, but the results are not available. Could someone help me to understand what is wrong with my program?
Thankd.
Thankd.
RE: ANSYS LS-DYNA
-Brian
RE: ANSYS LS-DYNA
I'm used to write a scipt in Notes pad, which I excute in ansys, and I do the same this time with ansys ls-dyna, in my script I always follow the same steps, /PREP7,/SOLU(finished with SOLVE command), than /POST1 to view my results (strains according to x, y, z directions), in the end of the simulation a result file is generated, but a warning tells me that EPTO data is not available.
Lyes.
RE: ANSYS LS-DYNA
-Brian
RE: ANSYS LS-DYNA
Simulation Environment: ANSYS
Licence: ANSYS Structural/LS-DYNA
ANSYS 9.0
Lyes
RE: ANSYS LS-DYNA
Good luck!
RE: ANSYS LS-DYNA
Thank you.
Lyes.
