SolidWorks & COSMOS 2007 SP0 have been released
Quote from SolidWorks web site:
Quote:
SolidWorks and COSMOS 2007 SP0 have now been released. All products in all supported languages, for both 32-bit and 64-bit Operating Systems, are now available for subscription customers to download from the following area of the SolidWorks web site:
http://solidworks.com/xxxxxxxxxxxxxxxx
Release shipments, including CD/DVD media, will commence in August.
Bradley
RE: SolidWorks & COSMOS 2007 SP0 have been released
Flores
SW06 SP4.1
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
For some reason it's not loading the page for me. It is slow then I get a blank page. Anyone else having the same problem?
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
Probably alot of people downloading it and the page is taking to long so IE sees that it's not loading.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I am with the rest of you. We will not run production work on SolidWorks 2007 until it is at SP 1.0.
Bradley
Its not even close. Speed of render, options of lighting, mapping, materials, caustics, GI, every aspect, pales in comparason.
If speed is your goal, stay with max and look into Vray, I always found it faster than brazil, although brazil has a certain look to it that I always liked, when it was done correctly. Brazil always seemed harder than vray to get the lighting just right.
Just having photoworks 2 turned on as an add-in slows large assemblies that have textures it seems. Never did solve that problem. We had to have our designers turn off photoworks till the very end of modeling before turning on in order to not bring the system to a crawl.
Randy
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer/AI student
Save your money and get a top of the line CPU and video card, since those are usaully the limitations to most systems.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Does a bear S*#t in the woods?
Does a triangle have three sides?
Is a frogs a** water tight?
Bradley
They released 2007 SP0 before fixing all of the problems with 2006... typical.
We will upgrade around SP2 or 3 when it is somewhat stable.
-Jeff
SW2006 SP4.1
Not as slick as how Alibre handles it but a step in the right direction. The only thing left to make it better in my opinion is to ask you upfront where you want to install Solidworks and add-ins and set the settings, then handle the rest of the installtion hands-off. As it is now....you still go through the same installation dialogues one at a time which happens to be a little different for each program (Swx, DwgEditor, eDrawing, PDM/works, etc.).
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP4.0 on WinXP SP2
Stefan Hamminga
EngIT Solutions
Not me. Only tried small parts and drawings.
Bradley
I did beta. It seems like they did a lot of stuff for premium, but I see the least amount of change in the core stuff. The only new feature is free form on 4 sided surfaces. The gui's a little different. I crashed it a bunch using scanto3d and routing. It seemed fairly stable in most core functionality, but who knows what oddities will pop up.
Overall, I have to say I'm not really that excited about this release, seeing as I don't have premium. Plus, most of the places in china that we work with, who use my SW files and not just my solids won't be on 07 for a while, so I can't use it anyway.
RFUS
All the other stuff is in the core.
New spline enhancements
Belt/chain assy feature and sketch feature
Isolate
Save Document Notification
New Gui for sutomizing keyboard shortcuts
Pack N Go
Solidworks Explorer rewritten
Screen capture
Full screen mode toggle and hide feature tree toggle
Equal Relations in 3d sketches
Realign sketches
Fully define a sketch
SketchXpert and MateXpert to resolve over-defining issues
Selection Manager for Lofts, sweeps, and boundary surfaces
Boundary surface
Freeform edit
Hole Series enhancements
Rack and Pinion mates
Break drawing view in both directions
Relative View works with cyclindrical bodies now
Custom Properties in balloons
Drawing Block enhanced
Different ways to display fraction dimensions
Multiple radius dimension leaders
Dimensions linked to notes bring symbols and tolerances with them.
Curved sheetmetal flanges
Jason
My overall opinion is like "Tony the Tiger"... It's Grrrreat!!
Even if most of you don't use it for production which is the smart thing to do. You should still fully test it with copies of your files just to see how it works with your products. YOu might find a serious bug in SP0 and if it doesn't get fixed in SP1.. when you move to it, that bug will still be there.
Best regards,
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Scott...does the "Save Notification" flicker on your PC? Most times I don't see it cause when rotating, panning, and zooming.....it flickers and thus faintly shows. Sometimes I only know it's there because I caught a faint flicker out of the corner of my eye. Then I move the mouse pointer down to the lower right and it appears. I have a gaming nvidia card so I figured that was the problem but I was wondering if others see it with Cad video cards.
Jason
Idid recently get a 2 drawing files one from SW06 and one while working on it in SW07 as a SW07 file, corrupt on me. THe SW06 file would not save to the new SW07 version. SW is looking into the issue. Other then that I have not seen much else.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
http://for
I haven't used SW07 yet because it's too young (SP0), but those on that forum are griping quite a bit about it. I will give SW credit for leaving that thread on their forum; not censoring those who slam their product.
Flores
SW06 SP4.1
Anne Van Epern
C.G. Bretting Mfg., Ashland, WI
www.bretting.com
SW 2006 SP4.1 DBWorks 2005
Quadro FX 3000
Pentium 4 2GHz 1GB RAM
WinXP 02 SP2
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Personally I feel that 2007 SP0 is the most stable SP0 release I've seen (2001 and up), better than SW2006 SP1.
Stefan Hamminga
EngIT Solutions
JMO again!
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
My VAR was semi-clueless.
My problem is there are a lot of Viewer users in my company that are still on Win2K, and their Department Head does not have the buget to upgrade his users to newer operating systems. If I could know for sure that the SW07 Viewer works on Win2K then upgrading is a non-issue for usu.
"Art without engineering is dreaming; Engineering without art is calculating."
Steven K. Roberts, Technomad
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
We had the same problem a while back with the SW viewer. We have some people in Windows 98. It was at that time we went to E drawings for our viewer and this seems to work just fine for us anyway.
Roger
Windows 2000 is not a supported operating
system. Please upgrade to a recommended
version of Windows:
http://www.solidWorks.com/pages/services/S...
Bradley
