Create a surface from point cloud
How do you create a surface from a point cloud? The surface will be used to cut a profile in a part.
Ken
RE: Create a surface from point cloud
go here to get the point import macro
http://solidworks.cad.de/mm_24.htm
Bring in your ASCII delimited point data. You will then have to use selection filters to select points. Then use Insert->Curve->Through Reference Points. Use lofts, sweeps, or surface fills to create your surface from these curves. Hopefully your data is not noisey.
2007 premium has Scanto3d tools. I evald and wasn't to hot on it. I'll stick with my reverse engineering tools.
This thread was one I remember
thread559-144042
RFUS
