Valve support
Valve support
Valve support
I have a 48" oil line having gate valves on it.
A gate valve is defined by two node numbers (a rigid).
I want a one restraint for a  valve. How can I put the restraint. On which node should I put the restraint. I want the restraint to support the valve by the center of gravity.
thanks in advance
RE: Valve support
Then model the valve as two back-to-back rigids, and put the support on the middle node.
Richard Ay
COADE, Inc.
