STL Import - Faceted Body
I need to make a sheet or a solid from an imported stl file.
What I get after the import is an faceted body. Is there an easy way to make a sheet or a solid from this, that could be exported to IGS after ?
Thanks and best regards,
Sebastian
Sebastian
RE: STL Import - Faceted Body
Ben Loosli
Sr IS Technologist
L-3 Communications
http://www
You may wish to pay close attention to John Baker's reply.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Basicly it means there is no way to do that in UG, right?
