Bulk Modulus of Hexene & Propylene Oxid
I am searching for the bulk modulus of hexene and propylene oxide. SI Units preferred.
I need the information to determine the wavespeed in a surge analysis.
Geoffrey D Stone FIMechE C.Eng;FIEust CP Eng
www.waterhammer.bigblog.com.au
RE: Bulk Modulus of Hexene & Propylene Oxid
For hexene you can use the formula for hydrocarbon liquids posted at this thread,
http://www.eng-tips.com/viewthread.cfm?qid=159698
I have nothing on propylene oxide. You might want to cross reference this question on the petroleum engineering - "other topics" forum. Do you have viscosity data points for propylene oxide? Just curious what fluid type classification it falls into.
Going the Big Inch!![[worm] worm](https://www.tipmaster.com/images/worm.gif)
http://virtualpipeline.spaces.msn.com
Thanks, I got the information I needed from AFT's Chempak.
PO is UN # 1280 transport Class # Packaging Group 1 Storage Class 3. Your mnay know by other names such as 1,2 Epoxy Propane.
