Cleaning large running sewers
The mill I'm at has a gravity sewer system which flows through 1200mm pipe and through various distribution boxes. Flow rate of 900 to 1100 l/s. Flow rates during maintenance days are around 50 to 300 l/s. Temp is 50 to 60 deg C
To avoid costly bypassing is there a way to clean the ditribution boxes / pipe while running to get rid of the rocks & debris which I believe are stopping the slide gates from closing properly.
RE: Cleaning large running sewers
Ask respectfully. My experience is that they will respond in kind.
Good luck
