Pro Engineer regeneration glitch
Could anyone tell me how to make Pro Engineer stop orienting back to the default postion after I have made a change.If I am zoomed in on a particular feature to edit and regen,the part always goes back to the (control+d) position.Ughhh
RE: Pro Engineer regeneration glitch
- For an individual Pro/E session use the ENVIRONMENT menu.
- For a permanent change, include one of these lines in your config.pro:
ORIENTATION ISOMETRIC
or
ORIENTATION TRIMETRIC
If you would like something completely different, create your own default view -- which can be anything you wish to set in your config.pro.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
You may also want to use the View Previous option so you don't have to save every view orientation. This will work for any orientation you had before the Regen returned you to Default position.
Michael
The view-->previous tool is invaluable, and I set it up as a button right next to my view selector.
