Has anyone used domestic water main as a heat sink for a water source
heat pump system?
I want to attempt it, but the principal (Owner) is not willing to guinea pig, and wants me to find other successfull installations first.
Essentially I want to "borrow" water from a domestic main, run it thru a plate and frame HX and re-inject it back into the main at a point downstream from where I took it.  This will essentially utilize a very abundant heat sink for a large(ish)(400 ton) water source heat pump system.
Any ideas of where I can find examples of where this has been done before?
Jabba
RE: Has anyone used domestic water main as a heat sink for a water source
I would strongly advise against doing that.  Do you want to be responsible for someone getting sick from contaminants in the heat exchanger?  Remember, you are dealing with POTABLE water, which must be protected at all costs against contaminants.
Look for another method.
In today's energy hungry world, we need to, in my opinion, lead the way to save energy.  I think this has already been done.  If it has not been successfully installed, the ol'man will NOT allow it.  I expect to get denied by the water utility as well, but that does not relieve the political benefits of suggesting a progressive approach and making someone else make the difficult decision to use more energy.
I agree with you in principle though.  At this point it is merely an exercise in conceptualization.
Jabba
Not to mention that I would be pissed if my cold water is sitting at 85ºF because of your heat dumping.
TTFN
Do utility companies guarantee water delivery at certain temperatures?
On the plus side... that would save money on the domestic water heating side of things too.  Good point.
Jabba
Not if I wanted COLD water first.
You've still got the liability of protecting the water from contaminants of all sorts.  ANYONE with intestinal ailments will immediately suspect your installation as being the cause
TTFN
Again, I stress that I do not expect that this will fly.  Someone, somewhere will shoot it down, but I think it's been done before.  I just can't lay my hands on when or where.  I remember reading an article once in the far back parts of my brain about it.
I am just hoping that someone here can point me to an article or case study or something.
Jabba.
You need to understand where the box is and why the box is before you think outside of it.
One issue with the water supply, particularly residential, since the water flow is sporadic during the day, which means that you will not be able to get stable flow and heat removal.
Another issue is that if you are the only person doing it, then you get cold water.  If there are 10 people doing it, then you're going to get lukewarm or warm water and there is less heat transfer to be had.  That's in addition to the contamination probability increasing and the increased disruption to the supply as more people attempt to tap into the main.
Given the limited utility of the concept; dollars to donuts, any water authority would nix the idea and possibly lock you up as a danger to their customers. winky smile
TTFN
On a largescale project it would be possible if you had enough hotwater demand, it is not very different the the way we make potable HW now, problem is when your dhw use drops you lose your heatsink, might be best as an add on to a tower rejection system. plate+frame is out of the question for this application, as the potable water needs a double protection
Well, water volume is part of the reason it has to tie into a large main. Doing it off a branch is not an option here.
As far as what happens when everyone is doing it... just because it's not feasible for everyone does not mean it's not feasible for us.
I am considering using ground water from the site for this as well.  The hang up here is how much IS there?  It is a 10 acre site, with an underground parking garage over the WHOLE 10 acres.  Ground water drainage estimates have been from 500 GPM to 30,000 GPM.  Since it's being constructed in phases, we're going to build phase 1 and see how much there is.  If we can use it then... we will if not we won't.
I still think someone has actually done the domestic utility tie in thing.  They do make food grade anti-freeze as well, so even if there was a leak... it wouldn't hurt anyone.  And we could always double, redundant isolate the domestic water from the source loop as well, IF the numbers supported the idea.
And I still think we owe it to each other to push the edge of energy effecient design.  Someone HAS to be first to try something new, or else we'd still be living in the stone age right?
Jabba
If energy saving is the goal, how much energy saving has gone into the building envelope in terms of reducing the cooling loads and heating loads in the first place?  Exterior shading?  High performance windows?  Thermally improved exterior wall details with minimal thermal bridging?  The plan should be to minimize the energy loads through passive means before tackling the active systems.  I know of geo-exchange systems where a closed loop geo-exchange pipe system is installed along side/under water and sewer pipe trenches to take advantage of the "free excavation", but I am skeptical that using direct "water main water" through a heat exchanger is a wise thing, given the legal and health issues associated with the protection of the potable water supply.
I know of a firm (www.cobaltengineering.com) that is designing a direct water main heat pump system for a project in the Vancouver, BC area, but I don't know the details, and am watching it to see what transpires there.  I believe the project is called the "Montenay" project.
Maybe I'm missing someting but with a double wall heat exchanger how is this different that using a glycol hot water heating system to heat your domestic.
I'm not a real engineer, but I play one on T.V.
 A.J. Gest, York Int./JCI
I believe your water utility will simply say no and roll around on the carpet laughing.
The ground water idea may be possible, especially if you pump the heated water back where it came from. It all depends on how much reliable flow is available.
What is wrong with just purchasing a commercial packaged cooling tower like everyone else does?
Instead of using water from a water main to warm the evaporator side of the heat pump, have you checked other sources such lake water, well water, river water  or even ambiant air(if the region is not too cold in winters)??  These other sources are used in heat pumps.
Some of you guys are killing me.  No disrespect intended.
The building WILL have a water source heat pump system.  It's a 400 ton system in a high rise building with retail, office apartment condo and very high end penthouses.  There are reasons why a cooling tower, evap cooler ground loop, air coupled or well systems are not viable.  The plan now is to use dry coolers on the roof of the 4th story level of the building, but there will be 6th and 7th floor penthouses that can look down on them.  The Architects HATE that.
I am trying to push for something that breaks out of the standard 400 sqft per ton, 400 cfm per ton rule of thumb, "this is how we ALWAYS do it" frame of mind.  Yeah I know using a city water main as a heat sink is not a common concept.  I know there are hurdles.  But, it is a fantastic concept to utilize a little used concept.  Think about it, there are MILES of already buried, underground piping there to use. Like a giant geothermal loop field, NOT being utilized.  It would also make the building MUCH more energy efficient to NOT have to run a cooling tower, or evap cooler or even dry coolers for that matter.
That's what I am trying to do here... push the envelope a little to make our business a little more energy aware.  Yes it would be EASIER for me to do what everyone else does everyday.
Again... I mention that this thread was just to ask is anyone knew about an existing system like this.  I am almost SURE there is.  I just can't find it, and to be honest I have not looked THAT hard either.
If I was too harsh in this post, I apologize.  I fight a battle at the office every day with a designer that is 65 years old, tired, ready to retire that does not want to LEARN about anything.  He applies rules of thumb to everything and screws up a lot of stuff that I have to clean up.  I am a little overly sensitive to the industry inertia to just do what we have been doing.
Just because something is new does NOT make it bad.  If engineers didn't think up new stuff... we'd all still be sitting around a camp fire chewing on bones and wearing hides.  C'mon people... help me save the world! ;)
Jabba
I suppose you could become a utility and sell potable domestic hot water to your neighbors.
use your waste heat and sell the heated water for what it cost you, hardly cost effective when you figure in the man power to over see, operate and test to meet federal specs.
but the public util will not let you re-inject anything back into there system.
With the area of parkade excavation, etc., have you examined all of the "free excavation" area to see how much horizontal geo-exchange potential there is?  Your "rules of thumb" are only applicable to the standard crappy envelope buildings- currently we are designing buildings where we mechanical guys spend a lot of effort helping the architect design a proper envelope with better glass and we aim for over 1200 sf per ton for cooling, or better.  Energy efficient buildings aren't about energy efficient systems, you have to minimize the heating and cooling loads first.  What do your building load calculations show as the high heat gain/high heat loss areas of the building?  Get to work on those before trying to figure out energy efficient equipment and systems.
Trashcanman, check this site out "geoheat.oit.edu/bulletin/bull18-2/art40.htm " which is an analysis on heat pumps using underground stream as a warming medium for the evaporator side.
The International Plumbing Code is pretty clear in preventing you from re-injecting back into the potable system.
What about splitting the supply into potable and non-potable for irrigation, toilet flushing etc.  The non-potable water can be your heat source, and this may be seperately supplemented with filtered rainwater off the roof.
Toronto has a system that uses domestic water (AFTER it bas been treated) to cool a chilled water loop via plate and frame heat exchangers.  They ensure a leak in a Hx will not contaminate the water in the domestic system by keeping the pressure higher on the domestic side (per an engineer with Enwave at a conference in Toronto 2 years ago).
http://www.enwave.com/enwave/dlwc/
or search for deep lake water cooling in toronto
Sort of off topic but relevant to the heat exchanger/domestic water comments posted above in this thread.
It has been a long time since I even looked at ground source heat pumps.  We considered that on a project for an observatory where the heat generated by a condenser would cause the air to shimmer, disrupting the view of the sky.
But at that time, the thought was to drill a well a couple of hundred feet maybe and run a closed loop down and back, making our own geothermal heat sink.
Is that not done any more?  That doesn't depend on the volume of ground water to do the heat transfer.
I do agree with some of what has been said.  Minimizing heat loads, running very low pressure drop duct and piping systems, simple, reliable equipment and controls has always served me well in designing energy efficient systems.
As you say, not everything new is bad...nor is everything new good either.  I deplore some of the things done these days in the name of energy conservation, that do nothing more than disguise systems that were poorly designed to begin with.
Yeah we still do earth coupled systems, both with horizontal and vertical fields.  The cost of installation for them can be very high.  In Indiana there are essentially only two contractors doing the field installation work, and thus... little competition.  Vertical well drilling is pretty expensive as well.
I am just exploring ways to use in conjunction with passive methods, to have the most energy effecient system I can dream up, with the lowest installed cost as well.
This is FUN stuff to think about, even if it doesn;t get built.
Jabba
Jabba -
I have client (school district) that wants to try water-main w/ water source heat pump system.  How did your situation work out?  Greader3@comcast.net
The prime responsibility of a Prefessional Engineer is public health and welfare.
Piping potable water through a chiller is an abrogation of this responsibility, whether or not you save energy.
Quote"If I was too harsh in this post, I apologize.  I fight a battle at the office every day with a designer that is 65 years old, tired, ready to retire that does not want to LEARN about anything.  He applies rules of thumb to everything and screws up a lot of stuff that I have to clean up.  I am a little overly sensitive to the industry inertia to just do what we have been doing.'
Your concept has zero merit and looks like the brainchild of an eager 14 year old wannabe engineer.
First off, you keep ignoring the fundamental issue of reinjection and pollution.(i.e.don't confuse me with facts) Are you going to guarantee a safe injection system. Second, how do you get this "infinite" supply of cold water and who guarantees the temperature and when you pump it back ,exactly where does this water go and who pays for the water you are using? Are you telling the utility you want credit for the warm water you are returning? Good luck.
And by the way what have you got against 65 year old engineers who don't "think" out-of the box like you, are they "tired".
Quoted... "Your concept has zero merit and looks like the brainchild of an eager 14 year old wannabe engineer.
And by the way what have you got against 65 year old engineers who don't "think" out-of the box like you, are they "tired"."
Response:
My mentor was 67 years old when we met.  He was neither old nor tired.  He embraced learning new things.  Was eager to calculate them properly, and did not take the path of least resistance at every opportunity.
I was not proposing running potable water directly thru a chiller.  I was proposing running it thru a heat exchanger to isolate the potable from the chiller water.  There are food grade plate and frame heat exchangers.  My safety intent would be to have the potable system at a higer pressure than the chillers condenser water system so if there was a leak... it'd leak OUT of the potable system.  And I don't know if you have any experience in city water or not, but it's NOT that clean.  They get mains that break all the time, and Joe Dirt jumps in the hole and patches it up with little to no regard for cleanliness.  It's not like our water system is a sterile, hospital like system anyway.  You are the one that does not want to be confused with facts pal.  I'm sorry your over the hill, and I'm sorry you think you know all there is to know.  Me, I do not know everything, and never will.  There is always new stuff out there, and just because it's never been done, done not mean it's a bad idea.  You just crawl back in your hole, and keep doing the exact same things you have been doing for the last 40 years. What's the big deal if you re-inject the water 10F hotter than you got it?
I did not think this up.  I read an article about it a while back.  So it had enough merit to get published in a trade journal.  My intent of posting it here was simply to have a discussion of interested parties.
To answer the question of how did it turn out... I knew all along I'd never get to do it, but still like to talk about ways to save energy.  We're in desperate need af saving energy now.  Our world, and out engineers have been throwing more energy at problems for far too long.  It's up to us (The next generation of designers) to help SAVE energy rather than squander it like our predecessors have been doing.
Jabba
maybe the young buck could learn a thing or two from the old guy zeke
Take the "V" out of HVAC and you are left with a HAC(k) job.
sorry zeke, you had the same point of view, will read the whole post next time
This morning the Water Utility rejected the concept for all the legitimate public health concerns noted by many of you.
FYI - The idea of using the utility water supply was being promoted by the Customer and I really appreciate having more than just my opinion to support my no-go decision.
I didn't read all the answers to the threads, but I'm glad to see so much interest in saving energy.
I also doubt very much if the water utility company will allow you to do ANYTHING with water except use it; many utilities require backflow prevention devices even on residential system to prevent any water from going back into their system.
However, have you considered using the floor of the parking structure as a heat sink?  Imbedded tubing in the cement floor of the parking structure would create a radiant floor system that could act as a heat sink (rather than using such a system for comfort heating or snowmelting as we do up here in the northland).  And adding tubing into a floor that most likely already has a wire mesh or reinforcing steel grid would not add that much cost.
I angled for earth coupleing (geothermal) early in the project and it was rejected.  Initially the developer thought he was going to do this with residential style heat pumps. LOL It took almost a year to convinvce them that that was not a practical approach.  Eventually we convinced them to go water source heat pumps, and finally to a central plant style system.  Now the gagage is already under construction.  To effectively use the ground loop for cooling, it really needs to be deeper than in the slab.  With the other earth coupled systems I have done here, they have been required to be at least 48" deep and some as deep as 72".
Utility companies are, in MY opinion a little bit hypocritical and over cautious.  I understand their position, but I think they are ignoring a great heat sink that COULD be designed to function safely, and could generate them revenue.  While conserving natural resources and saving energy.  I know, that water delivery mains are far from clean, let alone sterile.
Is 40 considered a "young buck"?  If so... thanks!
Jabba
Only part of the problem has to do with the fear of contaminants leaking back into the public water supply. There is also the problem of thermal pollution (cold water no longer being cold).
But much more objectionable is that heating water drives out the dissolved gases, especially the oxygen. This changes its taste and "quality" significantly. It is the dissolved gases in water that make the difference between ice cold water from a fresh bubbling mountain stream, and warm water from a stagnant shallow pond that has been sitting out in the sun for a while.
Both may be acceptably chemically and biologically clean water in the strictest scientific analytical sense, but the difference in perceived quality is very obvious to either human or animal.
Warp speed... that is the best "reason" that I have heard thus far.
Nice insight.
Jabba
How about instead of rejecting the water back to the utility, the water is used in the facility for flushing toilets, irrigation, etc..  This does not provide a constant heat sink, but the cooling capability of the utility water is realized and the quality of the water for the purposes mentioned is not an issue.
TTsquared, that's a great idea too... unfortunately, it would require a lot of additional plumbing to keep the thermally altered water separate from the unaltered water.
Not appropriate for THIS project.
Newest development... there is a lot of ground water at the site.  It's still a little undetermined exactly HOW much there will be, but they are thinking in the neighborhood of 500 GPM at it's slowest.  The have to collect it and pump it away anyway.  I am going to try to utilize this throw away water, thru a HX as a retro-fit to the central plant water source loop once it's established how much water will actually be available.
I'll not be depending on this heat sink, so if it dries up someday the system will still work, but it'll be a nice way to lower the demand on the evap cooler when it's available.
Jabba
