load analysis steel pipe
Can someone give me an idea of how to calculate load capacity on a steel pipe with a certain OD at a given length? Are there calculators online I could use?
TIA
TIA
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
load analysis steel pipeload analysis steel pipe(OP)
TIA Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: load analysis steel pipe
If so, there are allowable load tables in the AISC manual for different pipe diameters,wall thicknesses and different KL values.
I don't know of any java applets around that do it, but I'm sure you could find one if you look hard enough.
Going the Big Inch!![[worm] worm](https://www.tipmaster.com/images/worm.gif)
http://virtualpipeline.spaces.msn.com
Even if you pursue this, you are going to need a qualified welder and many fittings to make the joints. I recommend you contact a prefab bridge producer before getting too much farther. CONSPAN manufacturers precast concrete bridge products that can easily span 30 feet, but are designed for substantially more than a tractor. U S Bridge manufactures prefab steel trusses. Their off the shelf stuff would likely also be more substantial, but they may be able to produce something closer to your needs. Good Luck
Moment = 5000 lbs * 30 ft * 12 in/ft * 1/2
Bending stress, Fb = Moment/Section_modulus, I estimate that it should have an allowable of around 18 ksi for "unknown" pipe.
Where section_modulus = I/r
I = moment of intertia
c = radius to outside of pipe
calculate "I" here,
http://www
Needs adequate lateral bracing.
Now, how much do you really need that tractor across the stream?
Or, maybe I should post the following on the Electrical Engineering forum:
Guys:
Although I'm a structural engineer, I need to design a substation, to power my home and 5 neighbors' homes. I have a Costco generator, and approx. 50 feet of wire. Any tips?
tg
Download RamAdvance's demo version, and see what happens when you design your frame, and put vehicle load on it.
h
Excellent book, the problem is it was written in 1915. Probably 90% of it has only historical interest or is far too specific, but you may learn a lot from the remaining 10%.
www.SlideRuleEra.net
how are you going to make a decking to distribute the load ?
maybe you could align 2 pairs of pipes to make two tracks, but that sounds a bit dodgy. you'd need to join them together (welds). maybe nest one of your smaller pipes between two large ones; also add some small ones as cross bracing.
maybe you'll be alright ... good luck !
