Cutting hole is ASCE rail
Is there anything to contradict cutting a 1/2"-3/4" hole through a section of ASCE rail at 8'-0" centers for the length of the rail.
I believe the rails are ASCE 30 rails.
The intent is to provide drainage across a set of door rails and allow the water to move from one track to another and eventually run off.
RE: Cutting hole is ASCE rail
