API 650 Appendix 'J' Air Test
API 650 Appendix states that for tanks 12'-0" or less in diameter a maximum pressure of 5 psi shall be used. Can a lower test pressure be used for this size of tank, between 2 psi and 3 psi for example?
RE: API 650 Appendix 'J' Air Test
