DIFFERENCCE BETWEEN WEDGE GATE VALVES AND SLAB GATE VALVES
hi please let me know the differencce between wegde gate valves and slab gate valves.
RE: DIFFERENCCE BETWEEN WEDGE GATE VALVES AND SLAB GATE VALVES
http
Going the Big Inch!![[worm] worm](https://www.tipmaster.com/images/worm.gif)
http://virtualpipeline.spaces.msn.com
OK, here's the walworth
h
The basic difference, as you can see now, is one seals against leakage using a force applied to a wedging action against the valve in a downward direction, the other seals by line pressure pushing the slab horizontally against the edge seal, I believe it has springs for secure sealing at low pressure. Call up the reps and they will be all too happy to come in and tell you the advantages of each.
I don't have experience with Walworth valves, but I can say M&J are good valves.
Also i'm a client of AIVINC.
where are you from biginch?
i'm from Mexico city.
Thank you for all your help
From anecdotal evidence (ie hearsay), wedge gate valves can get "stuck" more often than a slab gate. I am guessing that "gunk" can get into the bottom of the seat, and not allowing the wedge to seal tightly.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
does wedge gate have top entry design?
becuase the slab gate desing has top entry design.
h
When the valve is being opened, the wedge moves up into the bonnet area. The line contents and pressure follow it. When the valve is closed, some contents and pressure remain in the bonnet area. The Stuffing (5) stops the contents & pressure from leaking. If the bonnet is removed by withdrawing bolts (6), there is open line pressure. The wedge will fly out. Major leak.
