Broken View Brake Line
Using v7, I'd like to use a Broken View to cut off the bottom of a view. I can do this by dragging the bottom brake line below the image, but then it throws the bottom brake line into the center of the view. Is there a good way to do this?
RE: Broken View Brake Line
Make certain that when you create the sketch that will define your break out, you select the view you want the break out associated with first and that you sketch a closed feature.
