SAE J1926/2 standard for male fittings
Has anyone got a copy of the SAE J1926/2 standard?
I normally only use the port standard, information for which I get from the Parker hydraulic fittings catalogue.
I now need to manufacture a pressure transducer body that ends in a -16 (1 5/16-12UN) male pipe shaft, and need to know what has to be done for the 'O' ring groove on the shaft that forms the seal in the corresponding port.
I've looked at buying both standards, but are in work in progress status on the SAE International website, so not available to purchase. British Standard suppliers can't source either.
Thanks.
Thanks.
