Can 35% H2O2 be used in rocket engines?
hey,
I have read in Rocket Propulsion Elements by Sutton and Biblarz that hydrogen peroxide is used as a oxidiser in rocket engines much like liquid oxygen, but it says that concentrations of 70% and upwards are used. My qustion is can food grade 35% H2O2 be used in a rocket engine setup? Is the concentration high enough? Will the overall result be just a lower thrust form the engine?
Thanks for your time.
Indy1687
RE: Can 35% H2O2 be used in rocket engines?
Isn't it diluted with WATER?
TTFN
IRstuff is right -- you'd have a steam-powered rocket!
The concentrated hydrogen peroxide sold to the average user, both reagent & technical grades, is 48-50 wt%, balance water.  There's some danger of spontaneous decomposition, so stricter safety rules apply for above 50% wt%.  A stabilizer is often added, as well.
You may want to check out the General Kinematics website, http://www.gkllc.com/. They have a lot of info on hydrogen peroxide use in propulsion.
Thanks for all your input and help. It has been very useful.
H2O2 in low percentage is not hypergolic.
Furthermore, it is extremely difficult to ignite, and to obtain a stable combustion from it
Everything should be made as easy as possible, but not easier
Albert Einstein
