Ammonia removal from wastewater
Wastewater contains 1000-5000 mg/l NH3, and must be reduced to <10 mg NH3/l for discharge. What methods are available? Raising pH and air-stripping is one obvious solution, but then the off-gas will have to be oxidised to remove the ammonia gas and this will require fuel, scrubbing and recycling. The wastewater is in a large tank. Can it be treated in situ?
RE: Ammonia removal from wastewater
If you need any more info about this, let me know.
qshtr
1. Combined carbon oxidation nitrification/denitrification in suspended growth reactor using endogeneous carbon source.
2. Combined carbon oxidation nitrification/denitrification in suspended growth using waste carbon source.
3. Suspended growth using methanol following a nitrification stage.
4. Attached growth (column) using methanol following a nitrification stage.
If you want a commercial proposal, please pass on your request to our VP Operations Les Smyth at lsmyth@tgeng.com
Courtney Dehn
Process Manager
TG Engineering Inc.
Calgary
Alberta
Canada
www.tgeng.com
You have a fairly concentrated source of NH3. Do you have enough volume of wastewater to economically recover the NH3 and sell it or make other products?
Tim
Other way is steam stripping, in a column with a short rectification section, to obtain amoniacal solution, i.e., 25 - 30%
Sp.
For a new ammonia removal technique, visit www.thermoenergy.com and follow the threads to download a peer reviewed report.
