DRAFTING SECTION VIEW GENERATING VIEW
Hi Group
I have a drawing with two section views cut from another view.
The trouble I am having is I cannot work out which view they are cut through.
Is there a way to discover which view was cut?
Any help would be appreciated
Dave
NX3 3.0.3.2
Dave
NX3 3.0.3.2
RE: DRAFTING SECTION VIEW GENERATING VIEW
I think the easiest way you can achieve the goal is:
Open "Part Navigator", right-click the section view and in the pop-up menu choose "Navigate to Parent". The parent view will be zoomed to fit the screen.
You can also use the "Dependencies".
_____________________________________
"Complex problems have simple, easy-to-understand, wrong answers."
_________________
PI Penkov
CAM Programmer
Non-standard Equipment Designer
