Tactile Sensor
Tactile Sensor
We have an existing indicator light that we would like to add a button function to. I have researched, and experimented with capacitive teouch sensors, which work very well for this particular purpose. The problem is that a gloved hand will not operate a capacitive sensor, and a stylus is out of the question.
A small resistive touch screen would do, but I have yet find any such product on the market. It need only be about 1 inch square, and respond to simple touch/no touch. I am considering making the part myself, but I am not in the habit if reinventing the wheel. Is there an existing product that might work here? Or perhaps there is another method of touch sensor that can be implimented.
An optical approach we suggested, such as an infrared emmitter/detector, but ambient light levels, and packaging contraints have ruled that out.
Any suggestions?
-EG
Any suggestions?
-EG
RE: Tactile Sensor
TTFN
RE: Tactile Sensor
I'm confused.. You want a non capacitor switch? Or a non capacitive overlay for a screen?
Keith Cress
RE: Tactile Sensor
The myriad of capacitive sensors, which can use any substrate as the actual sensor would work exceptionally well in this application except that they don't respond to non-conductive tactile input(i.e. a gloved hand). Form factor isn't a problem though, as we can use the lens of the indicator lamp as the sensor area.
So, I guess what we are really looking for is an off the shelf part that will fit the size requirements in a resistive overlay, or a method to create the same effect, without resorting to having the item custom manufactured, as we only need a few hundred at the most.
EG
RE: Tactile Sensor
Keith Cress
RE: Tactile Sensor
http://
TTFN
RE: Tactile Sensor
IRStuff-
That's getting closer. I'm contacting them to get more information.
If I only had the resources to work with ITO in house, this would be a non issue.
EG
