"Super" Global Variables ?
I have a Pillow Block Assy which consists of a Pillow Block Housing and a Bronze Bushing Insert.
I would like to have Outside Diameter of Insert and Inside Diameter of Housing - two Different parts !! - somehow linked from some place (Assy ??) by some "Super Global Variable", so when I modify that "Super Global Variable" both diameters in both parts would change accordingly.
Any hints ??
Any hints ??
RE: "Super" Global Variables ?
On the assy I made all Annotations , dimensions of parts visible. To do that I opened the tree of each part and made the above visible.
Once they are visible I simply added (on assy) equations between dimensions.
I also have a feeling this may work by having a Design Table in Assy ?? Will have to experiment a bit.
Any comments/suggestions ?
(I know it's Sunday morning but there is gotta be some folks out of bed already
"Dimensions in Configurations" says:
"You can not control the dimensions of a component contained in the assembly" ...
htt
Also check out Blocks > Blocks for sketching in SW help.
26 free tutorials can be seen in the download from http://www.solidprofessor.com/
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
