Would this be a viable patent claim?
"An electric rotating machine, which can be operated as either a motor or generator, utilizes material exhibiting a Hall effect to replace the normal slip rings or mechanical commutation devices. Preferably, a slab of Hall effect material is curved to extend circumferentially around the rotor between the rotor and stator, and the rotor is adapted to create a magnetic field. When used as a motor, a source of electrical power is connected to the Hall effect material to cause a primary current to flow therein. The combination of the rotor magnetic field and the primary current flowing in the Hall effect material produces a Hall effect current which creates a torque on the rotor causing it to rotate. When used as a generator, the rotor is rotated and induces a primary current to flow in the Hall effect material. The combination of the rotor magnetic field and the induced primary current produces a Hall effect voltage and current that can be connected to power an electrical load."
Could this be the abstract for a successful patent application?
It would be very interesting to hear your views. My view is chrystal clear...
Gunnar Englund
www.gke.org
RE: Would this be a viable patent claim?
Sounds plausible, since it does not violate conservation of energy.  That it might not actually work is not always a consideration.
The actual claims would have to be described to make the final judgement, since an invention must show an improvement over prior art.
That's the primary flaw of the abstract, in that it does not describe why the invention is necessary or better.
TTFN
The efficiency would be something like 1 percent. Or less.
Gunnar Englund
www.gke.org
At least in the US, practicality and efficiency doesn't usually stop a patent application from going forward.
The biggest variable is how effective is the search for "prior art".  Or, in other words, is this really a new idea or has it been thought of before and, especially, has a patent for the concept be applied for previously.
The record in recent years with the US Patent Office is that the search for prior art is superficial at best so the chances of a patent being awarded are pretty good.
If the concept later proves to be a valuable or profitable one, then the lack of a thorough search for prior art becomes a serious liability because anyone who wants to use your concept can, if they can show prior art thru their own search, get your patent invalidated.  Your expenses to get the patent and any defence of your patent that you have paid for is now wasted.
Some companies are now doing their own search for prior art before applying just to save the cost and aggravation of having a patent thrown out later.
Hope that helps.
The patent is 5,146,125
I think is absurd. The RASER company that we discussed earlier is the holder.
Gunnar Englund
www.gke.org
Hall effect material? Isn't the Hall effect due to the Lorentz force, where charges move at right angles to the current flow through a magnetic field? This means that Hall effect material could be renamed to "conductor"!
It could be a viable claim as written.
It could be a valuable claim if the Hall Effect were three orders of magnitude larger.
Like so many grand ideas, it awaits a quantum leap in materials science, or a miracle.
Mike Halloran
Pembroke Pines, FL, USA
If the Hall Effect were 3 orders of magnitude larger, wires wouldn't work correctly.
TTFN
If you ask me, this just sounds like a brushless synch motor excitation system, except they are trying to use Hall effect transducers instead of inductors across the rotor shaft gap. I don't see the point of doing it at all!
http:/www.jraef.com
Eng-Tips: Help for your job, not for your homework  Read FAQ731-376 pirate
Just a thought, by describing it as you have, is the concept now effectively "published" preventing you applying for a patent??
It is already a patent. Number 5,146,125. And it is not mine. I was just asking because I think it is totally weird.
Gunnar Englund
www.gke.org
Gunnar:
U R right - it is ridiculous. Part of it is possible and
part of it is new -- unfortunatelly the new parts
( Hall effect slab curved around the rotor, the full
current directly swithed by the Hall device etc ) are
impossible, and the possible features are not new.
Plesae read FAQ240-1032
My WEB: <http://geocities.com/nbucska/>
