Restraining SWPE Pipe On A 40 degree Slope
I need to anchor smooth wall HDPE pipe on the surface of a 40 degree slope for about on eyear. Then the slide will be rebuilt and the pipe covered. I also want to restrain the pipe in a 48" Diameter MH about 20 feet from the top of the slope. Any recommendations or sources?
RE: Restraining SWPE Pipe On A 40 degree Slope
Get a couple of these bolt-on-things, shown here,
http:
Just bolt them on so the hole for the tee exits horizontally and, without penetrating your pipe, screw in an 18" length of pipe into the location where the tee pipe connection should normally go. Don't penetrate enough to harm your pipe inside.
Slide on a cement block or two onto the 18" pipe length and fill the block and the hole around it with concrete.
I'd locate another one as close as possible, but with the tee going in the opposite direction from the first.
Going the Big Inch!![[worm] worm](https://www.tipmaster.com/images/worm.gif)
http://virtualpipeline.spaces.msn.com
http://ww
