Automation error?
Automation error?
Automation error?
I’ve just noticed a problem with SolidWorks Explorer. I don’t use SolidWorks Explorer frequently so I can’t say for sure when this started but I noticed it yesterday. The last time I used it, about two weeks ago, it worked fine.
Anyway, when I (try to) start SolidWorks Explorer, from both inside SolidWorks and stand alone, I get a message window that has “Solidmgr” in the blue bar across the top and the message:
  “Automation error
   The specified module could not be found”
in the box along with an OK button. When I push the OK button, SolidWorks Explorer appears to start normally but when I try to open a file I get another message window and SolidWorks Explorer crashes. This message window also has “Solidmgr” in the blue bar and contains the message:
  “Run-time errer “424”-
   Object required”
when I push the OK button the message window closes and leaves behind a garbled SolidWorks Explorer window. When I close that I sometimes get another error message, but not always.
I have tried the following:
Install current SW version, 2006 4.1
Download and install SolidWorks Explorer as stand-alone from SW download page
Compare the Solidmgr file to that on another machine that works normally
Do a “Windows Restore” back to a time when it all worked normally
None of these have produced any positive results. Does anyone have any other ideas?
Al
RE: Automation error?
Thanks Cor,
The solution in the link you supplied didn't work exactly as described but when I used regsvr32.exe to register Solidmgr.ocx (which I first had to copy to the Windows System32 folder)it did work and my trouble has been resolved.
Thanks for your help!
