curve to points
curve to points
I have got curve with help Curve Through Free Points
Can I get only points in order to create curve or spline by manual. Or convert present curve to points.
RE: curve to points
I hope that helps.
RE: curve to points
you can bring in a curve through free points using x,y,z coordinate points from a spreadsheet.
you can convert a spline into equal points if you so need to. For instance if a made a spline with 5 control points and I wanted to break that spline into 20 points, yet still have the control points in tact. This is an API function that you have to write a macro for, I have one if you need it. The only thing I have not been successful with at the moment is making those points update when I change the spline. working on this!
Did i answer the right question?
It's too early in the morning!
Jon Benavides
Fisher Unitech
Troy MI
RE: curve to points
There is an Excel program, that you can use to make a spline through free points using x,y,z coordinates. I have never used it, but I believe I seen it at the SW website under their Model Library or www.nhcad.com
I hope that helps,
Scott Baugh, CSWP
George Koch Sons,LLC
Evansville, IN 47714
sjb@kochllc.com
RE: curve to points
Fortunately I have other software such Mastercam there I convert ASCII points and edit it. After I create curve as I want then Import to SW. If you will have a time visit and see me at www.universal.ee/eng-art
By the way Mr. Jon Benavides could you send me macro that you mentioned earlier about break spline. I'll try to play with it.
RE: curve to points
Yes, i will send you the macro when I get into work this morning.
And to Scott, yes SW has the split curve functionality but you have to manually pick your point locations. The way i am describing will mathmatically break the line into equal sections independant of it control points.
Like i was saying though, its not perfect because I havent figured out a way to keep the points on the curve if I move one of the control poins, I wind up hvaing to re-run the macro...and to me that is NOT acceoptable. If anyone finds out how to do this and have it update with changes, PLEASE let me know how you accomplished it!
Jon
RE: curve to points
I have a spline that was imported from another program and it is not centered about the origin. I need to find out the extents of the spline, break it into equal parts and get the point on the spline with the highest-x value and with the largest y-value. If you could send that macro to me I would love to see it.
Kurt
kurt@sonsoferin.com
