2 speed single phase ac motor winding connections
  Lafert ac motor single phase 2 speed with 2 groups of leads for the windings. It is a capacitor run motor with no start winding . 3 leads to each speed  and no centrifugal switch . I am unable to get high speed to run at rated speed . runs but at low speed with a hum  noise . I can not get details from manufacturer and no local motor winders able to offer assistance .  Any suggestions . anyone have this problem before . the winding meter through good and of equal resistance . no opens or grounds . Arcman
RE: 2 speed single phase ac motor winding connections
arcelectric
Morning,
Have you tested the capacitor? A resistance check of the windings is not always a good indicator of their internal condition. A winding analyzer is your best bet.
Just out of curiosity, what is the nameplate HP, RPM, and voltage?
Has this motor been rewound, and possibly the leads have been mis-labeled? Did you follow a connection diagram? If you have ran the motor very long under the conditions you described, it probably is a moot point now.
Bigbillnky,C.E.F.....(Chief Electrical Flunky)
"No opens no grounds"= not moot yet!
Capacitor is a good idea. What about switch?
A government which robs Peter to pay Paul
can always depend on the support of Paul.
    - George Bernard Shaw
Hi Bill
Are you probing for a responsive op? There have been a lot of post and run OPs lately.
I was surprised you did not the question what are the resistance readings  you can have readings and still have a toasted winding. They should all be very close to same, correct?
I'll bet this is a fan motor.
Chuck
