New job, need some hints from the experts
Hello all, this may be my first post on eng-tips but I've been a lurker for years. I just started a new job with an aero-startup and I was originally assigned to stress on secondary structure for systems but I am currently needed for design work on the secondary structure. The plane is a mostly composite structure VLJ. This is the first time working on a general aviation plane and I need to get off to a good start but I've never done design work.
My question is: What are some of the most important things I should consider as I begin work on secondary structure (brackets, clips, etc.) for the hydraulic systems? I realize this may be the most vague question ever posted here, but any constructive advice would be greatly appreciated. More specific questions are: What are the faa certification documents I should be following, are there off-the-shelf composite brackets I should consider, what can I do to better understand the load paths in a 3000 psi system, and what are the less obviuos failure modes of a composite hydraulic system bracket?
RE: New job, need some hints from the experts
good luck
Good point, the structure holding up the heavy components will act more like primary structure in many cases. I am starting with the fuselage components but I would imagine there will be deflections to consider there as well. The pulse loads are yet TBD - any suggestions for documentation on this...? Thank you for your comments and suggestions.
HC,
Again, thank you for taking the time and for the great suggestions. The documentation suggestions are espeacially helpful. You are correct, I only have the bracketry for the systems, some simple Click-Bonds, clamp block brackets P-clips, and others that will need more detailed analysis. What type of substantiation is needed to use Click-Bond products? Buy all means, feel free to elaborate on the lightening and fire issues.
One other thing that comes to mind is thermal expansion loads. I would imagine that it would not be that big of a deal if the total length of an assembly were small, but long length of steel or aluminum tubing would be an issue.
You guys are really great to take the time to discuss this with me.
MIL-W-5088 has considerations for clearance with electrical.
Should you elect to use aluminum brackets most common protection I have seen is last ply of composite stackup should be fiberglass extending at least .25 all directions from aluminum component footprint. Both surfaces epoxy primed, fay, and fillet sealed with 870, ac665, or MIL-PRF-81733 whatever known as in your neck of the woods. Fasteners wet installed, and cap sealed on aluminum side of stackup with same.
Hope I didn't fly in from left field on this one.
Skypunk
That helps a lot, probably how most of the major bracketry I have should be installed.
Does anyone have any experience certifying Click-Bond products on carbon/epoxy composites?
