Flow Rate Restriction
I have a low pressure nitrogen gas system supplied from a 3000 psig source through a regulator. The regulator output flows through 6 feet of 1/4" diameter hose to the low pressure components. To limit the low pressure system pressure to 80 psig, the designer used a relief valve.
Problem. The full flow rate of the relief valve is less than that of a failed regulator. I need a method to limit flow to about 5-6 scfm. For a 3000 psig inlet pressure and 2950 psig pressure drop, the Cv is on the order of 0.001 but the Cv for a 0.03" orifice is only 0.016. Too many orifices. Needle valve maybe?
Any suggestions are welcome.
RE: Flow Rate Restriction
Different PSV maybe? 80 psig should be enough pressure to get 5 to 6 scfm even at 1/4" (though I will admit I haven't crunched any numbers). I've seen Swagelock spring loaded check valves used as PSVs in some service, have you looked at something like that?
Is your application precharging pulsation damper bladders on suction of a pump?
I'll keep the check valves in mind should I need to increase the relief flow rates rather than restrict the inlet flow.
You might want to look at FAQ798-1196 on how to calculate the choked flow of a gas through a restriction orifice.
Milton Beychok
(Visit me at www.air-dispersion.com)
