User Defined Scales
User Defined Scales
User Defined Scales
I am somewhat new to Solid Edge, mostly working with AutoCAD in the past. I have just started adjusting the propseed and other support files and I was attempting to change the scale values for the drawing view but I was unable to find a file that held that information.
Is there any way to change the values that appear in the drop-down menu for the scale in a drawing?
Any help you can offer would be a greatly appreciated, I have some experience programming and can access Visual Basic to tweak the program if necessary.
RE: User Defined Scales
AFAIK these values are not stored in external files. So they
can't be changed in any way
dy
Zacktangle,
I'm not sure about changing the values in that drop down.
It is possible to change the scale of a view, do you know how to do this or would you like me to explain?
Ken
