section lining
section lining
I would like to display a section through a gear. Drawing standards dictate the gear teeth should not be hatched (section lined) even though the cutting plane passes through them. I have the same problem with sections through webs.
Is there a way in UG of displaying these sectional views in accordance with drawing standards?
RE: section lining
Or do you need to hatch through the hub but not the teeth? If that is the case, you could turn off the hatching and define your own boundary to hatch (not elegant but it works).
RE: section lining
RE: section lining
Don't have access the documentation to find it, but it is something like: section_view = no.
Ben Loosli
Sr IS Technologist
L-3 Communications
RE: section lining
RE: section lining
If I'm following you correctly, what you describe determines whether or not the section lines are shown in the parent view. It's a checkbox in the dialog for creating the section view.
Cowski,
I have used "section components in view" quite a lot. What it does is defines which components are actually cut in the section view. Unfortunatly does not control hatching of components.
I'm not familiar with nor have I found any way to apply hatching to only select components. I've checked the documentation and the only thing I can find is the checkbox in the Style dialog.
RE: section lining
Thanks for the correction to my post.
RE: section lining
We had a part attribute that we added to our hardware items that would prevent them from being hatched when they were cut with a cutting plane for a section.
This is from the V17 Drafting documentation:
Creating non-sectioned components
Component parts added to an assembly, by default, are sectioned in section views on the assembly part drawing. You can make the components non-sectioned, by setting the user-defined part attribute section-component as follows:
Make the component part the work part.
Choose Format—>Attribute—>Part.
Choose Assign.
Enter section-component as the title for the String Attribute and choose OK.
Enter no as the String Value and choose OK.
Choose OK to dismiss the Enter Title For String Attr dialog.
Ben Loosli
Sr IS Technologist
L-3 Communications
RE: section lining
Have you tried Edit?Crosshatch Boundary? It's pretty well covered in the help files. Does this solve your problem or am I missing something?
_____________________________________
"Complex problems have simple, easy-to-understand, wrong answers."
_________________
PI Penkov
CAM Programmer
Non-standard Equipment Designer
RE: section lining
RE: section lining
_________________
PI Penkov
CAM Programmer
RE: section lining
RE: section lining
1. expand the member view
2. sketch the boundary needed to be included
3. switch off expanding the view
4. edit->crosshatch boundary
5. choose "Add" option
6. select the crosshatch
7. select the boundary
8. hit "apply" or "update crosshatch"
Does this help?
_________________
PI Penkov
CAM Programmer
RE: section lining
Sorry, I misunderstood your post. I thought you were talking about turning off section lines in your original post. What you describe in your last post is setting a component to not be sectioned. This can be accomplished by using Edit -> View -> Section components in view. I was not aware this could also be done with an attribute.
PennKoff,
Looks like an good solution.
RE: section lining
Since our hardware parts were generated from a master file, we put the attribute in that file and all new hardware files had the attribute when they were created.
Ben Loosli
Sr IS Technologist
L-3 Communications
RE: section lining
Yes, it's a good one. I believe that's the job dakeb wanted to do. I'm not fluent in english.
_________________
PI Penkov
CAM Programmer
