Rudder trunk antistowage grating
Hello
I am being proposed to fit antistowage/anti drug trafficing grating to the rudder trunk of some vessels.
So i have some questions concerning..
 1. The minimum size of the openings
 2. The type grating (metal bars or checker plate)
 Do you have any idea about that? any proposal?
 Also i am taking into consideration that must be a reinforced construction(avoiding any damage due to bad weather) with a hinged opening for neck bearing inspection.(the space which i want to be covered is 800x1000 mm)
