Steam boiler water level / feed system
I have 2 old 100 HP Kewanee 15 psi steam boilers in a basement and have been asked to replace one 1 of them. The condensate is all gravity return into a common header at the lower back of the boilers.
Do to access, my new boiler will have to be sectional and built in place. I have been told that I will never be able to match the water line, and therefore will need a boiler feed system.
I don't fully understand. Is this true? If so wouldn't the feed system have to serve both the old and new boilers? Would I be better off leaving the condensate alone and just replace both boilers?
RE: Steam boiler water level / feed system
You can also add a pumped condensate system.
Why you are replacing only 1 boiler of a set of 2 is another question....are both old boilers the same age? Why are you replacing only one?
Let's assume that I will have to raise the new one. I will then have to pipe up from the condensate header into the new boiler. And now that I say that, my condensate header and all of the return line dumping into it must be full up to the water level, correct? The return header is very low - almost on the floor and it goes into each boiler down that low. I assume that the condensate header is "backed-up' high enough to match the boiler water line. In that case, having a new boiler that is raised off the floor shouldn't be a problem - as long as the water lines match.
Any other thoughts?
Boiler feed units are sized according to the steaming rate of the boiler vs. the system's time lag (which is different for every system!). Also remember we're not talking about all the water in the replacement boiler-only the amount found between the normal water line and the low water cut-off level.
If this sounds like a solution to your problem then go here:
http://www.bellgossett.com/Press/art.html
