soft start / stop 220vac ac comp motor
hello i recently installed a ground source heat pump in my house. it is supplied by a well that was already on the property. i am most proud of the fact that i raised my efficency in my house and that i am less dependent on the oil companys.
my concern is when the unit stops its cycle. the compressor drops out with a considerble thump. is there a simple device that i could put on the motor circuit that will soften the shut down of my new hvac unit. the concern i have is for the shock to the copper pipes and the joints in the freon system. thank you ever so much for your time. also in closing i would recomond this type of hvac system to everyone. thanks barry
RE: soft start / stop 220vac ac comp motor
Gunnar Englund
www.gke.org
Keith Cress
http:/www.jraef.com
Eng-Tips: Help for your job, not for your homework Read FAQ731-376
