Ground Fault CT
Ground Fault CT
Does anyone have a new or used ground fault sensing CT for a Federal Pioneer Electric relay? The CT is rectangular with a 4 x 17 inch window, part number R4-17A. We have had a failure and require one ASAP. Factory delivery for a new one is too long.
Thank you
Doug Mortimer
Orbis Engineering
Thank you
Doug Mortimer
Orbis Engineering
RE: Ground Fault CT
Is the ratio low enough that it is feasible to hand wind it with magnet wire? It may not be perfect but it should serve until a new one is aquired.
respectfully
