steel concrete connections
A structure with PT slabs supported on tubular steel columns and RC cores. The columns are too small to fill with concrete. How do I provide vertical ties and connect the columns to the slab other than by direct bearing?
RE: steel concrete connections
With a small column, punching shear could well be a problem, has that been checked?
