Dim manipulation
Dim manipulation
Dim manipulation
Is there a value or formula you can apply to a dimension in a draft that will hide the dim or overide it so you can place text between the extension lines? TIA
I've seen it in other software.
Adam
Solid Edge V17
Windows XP Pro
RE: Dim manipulation
If you’ve got your toolbars set up like mine and I’m understanding your question it’s easy.
Create your dimension.
Select it (goes pink)
Go to the Select Tool – Dimension type (top tool bar) and select the grayed out x.  This hides the actual dimension value.
Go to the Select Tool – Prefix and type in the text you want, probably in the prefix box.
Hope it helps.
Thanks!...i'll try that tommorow at work. I'm at home now, chillin drinkin' a Heineken
Adam
Solid Edge V17
Windows XP Pro
Thats what i wanted thanks!
Adam
Solid Edge V17
Windows XP Pro
