INTELLIGENT PIG TRAP IN VERTICAL POSITION
Intelligent Pig Launcher is suggested to be positioned in the vertical position in an offshore topside design for reason of space constraint. Is this conventional and what are the pros and cons of such position.
RE: INTELLIGENT PIG TRAP IN VERTICAL POSITION
Not sure if this helps you.
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Smart pigs bigger than about 6-inch are too heavy to manhandle so your platform lifting equipment needs to be able to get over the launcher barrel.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The harder I work, the luckier I seem
Going the Big Inch!![[worm] worm](https://www.tipmaster.com/images/worm.gif)
http://virtualpipeline.spaces.msn.com
David
David
