Tubing?
Tubing?
I have designed a tubular chassis does anyone know how I can flatpattern my tubes so I can have all the coping done with laser? Can I use another program like inventor or somthing to achive this? I found a cnc tube bending sofware that allows me to import solidworks files but I dont want to buy it if it will not flat pattern and show the coping.
RE: Tubing?
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
RE: Tubing?
RE: Tubing?
Or do you mean just straighten bent tubes? You may be able to use the Routing module for this.
Some lasers have accesories which can cut tubes ... one side at a time if necessary.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
RE: Tubing?
Notch orientation could be made in the bent state, or the bend could be made relative to the notch.
RE: Tubing?
RE: Tubing?
RE: Tubing?
RE: Tubing?
RE: Tubing?
RE: Tubing?
RE: Tubing?
A tube bending machine may be different, but I think it would be easier to align a cut end to a formed part, rather than align a form to a cut end.
RE: Tubing?
Tube and Bending manual in English
Wall chart int English
http://www.toolsforbending.com/literature.asp
To download, just enter a 1 or a in the required fields.
Flores
SW06 SP4.1
