LLD pipeworks problem
I am getting and error when trying to create a pipe run. Has anyone every seen this error before and if so how can I fix it?
Field 'Run Data Table.PIPE_NAME"
cannot be a zero-length string
RE: LLD pipeworks problem
"Everybody is ignorant, only on different subjects." — Will Rogers
Draw a polyline along the pipes to be profiled.
Define an alignment from this polyline.
Set the desired surface to be "current".
Define and name the pipe run from the Pipes menu.
Sample and create a profile from "Profiles".
Import the "conceptual profile" from pipes onto the profile.
Select "concptual profile, edit data", and the editing table for the selected run will come up.
Use the pull-down menu on the table view to choose the "pipes" data table, on which the first column must have a name for the individual pipe segment.
I usethe CivilDesign modules quite regularly at work. If what I wrote isn't clear enough, please don't heistate to ask more questions.
