coincident but not merged points
Whenever I try to create a base flange from a tab. I get a message that says "The highlighted entity contains points that are coincident but not merged. What does this mean? How can I fix it.
RE: coincident but not merged points
This probably means the points happen to be coincident, but ought to be merged for the operation you're doing.
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
Test by dragging points. You'll know which sequence you converted the entities, so this should give you a clue as to where to start.
To avoid this in the future, select all your edges at one time (or as many as you can practically do) and then convert them to line segments.
Jeff Mowry
