Material properties as function of RD
Hi all,
I need to express Youngs modulus and poisson's ratio as a function of Relative Density in ABAQUS Standard.  Any ideas or insights on how to do this?
Chris
RE: Material properties as function of RD
How does the density vary in the model? If it varies with temperature or spatially then express E in the same relative manner.
corus
can you offer any suggestion on how this would be done?  Density in this case is varying spatially.
chris
You'd have to use a subroutine, UMAT, I believe. The co-ordinates should be available to use as a variable there.
corus
