Use of Super Duplex UNS S32760 for ASME VIII U Stamp Vessels
Is it acceptable to design and fabricate ASME VIII : DIV I : 2004 U-Stamp vessels from Super Duplex ASME SA240 UNS S32760. This material can be found in ASME II part A but not in ASME II part D. If so can the stresses for Super Duplex ASME SA240 UNS S32750 be utilised.
RE: Use of Super Duplex UNS S32760 for ASME VIII U Stamp Vessels
You should check if there is a Code Case (I don't have mine handy). If there is, that will provide the allowable stress values and other requirements/limitations.
Also, check with the material supplier. They generally have people on the various committees and they may be able to tell you if there is an approved code case (and give you the number so you can obtain a copy) or if there is one in the process and when it is expected to be approved. Obviously, if it has not been approved you cannot use the fact that one is in process to justify use of the material.
25Cr-7.5Ni-3.5Mo-N-Cu-W Alloy, UNS S32760 Forgings Plate, Sheet, Strip, Bar, Seamless and Welded Pipe and Tube and Fittings Section VIII Division 1.
Has all you need in the code case.
