Rust Proof Paint
Rust Proof Paint
What is the best course of action to remove the existing rust/corrosion and paint the steel so that we could get at least 15 years out of it. The environment is pretty harsh with hot moist summers and below freezing winters with snow and ice. The paint will be used on the stairs as they will be exposed to salt/calcium chloride. Also, the location is close to the ocean and has to resist salt air as well.
RE: Rust Proof Paint
Cory
SSPC-Paint 28, Water-Borne Epoxy Primer for Steel Surfaces
SSPC-Paint 36, Two-Component Weatherable Aliphatic Polyurethane Topcoat, Performance-Based
These are available at:
http://www.sspc.org/standards/scopes.html#paint
And here are some from the US Military:
MIL-P-53030A PRIMER COATING, EPOXY, WATER REDUCIBLE, LEAD AND CHROMATE FREE
MIL-PRF-85582 Primer Coatings: Epoxy, Waterborne
MIL-PRF-85285 COATING: POLYURETHANE, AIRCRAFT AND SUPPORT EQUIPMENT
MIL-DTL-64159 COATING, WATER DISPERSIBLE ALIPHATIC POLYURETHANE, CHEMICAL AGENT RESISTANT
http://assist.daps.dla.mil/quicksearch/
Cory
