Hydrogen storage carbon steel material?
Can anyone suggest a specific material specification for a hydrogen storage vessel - 24" diameter carbon steel 580psig -40F to 144F ASME Section VIII, Div. 1
SA 516GR70? SA333GR1? - Impact tested per material specification
Vessel is in cyclic service - 88000 0 to full pressure cycles over 20 years service.
Hydrogen embrittlment Concern?
Is radiography a code requirement?
Thanks in advance.
Any help would be appreciated
Thanks in advance.
RE: Hydrogen storage carbon steel material?
Reply; What are your impact test requirements for the vessel. What is the minimum design metal temperature? Answers to these questions will dictate material selection.
Reply; No
Reply: You need to follow the design requirements in the ASME Boiler and Pressure Vessel Code, Section VIII, Div 1.
Minimum design temperaure is minus(-)40F.
The two materials I mentioned would be impact tsted per material specification requirements at minus(-)50 F.
Vessel is in cyclic operation - 88,000 fill and empty pressure cycles from 0 psig to 580 psig over its lifetime. I would use a stress range reduction factor of f = 0.6 in addition to any joint efficiency factor E based on the extent of radiography performed in the design.
My primary question is - did I select an appropriate carbon steel grade of material for the application? Are there other specifications and grades of carbon steel that are more commonly used for hydrogen storage vessels?
