Helix Sheetmetal spring
Is there a way to unfold the helix spring I modeled? (see attachment) I created this using a rectangular sketch of material thickness and width then swept about a helix curve.
I also need to add four equally spaced features in each coil throughout the length of the spring. I have no idea how to do that.
Please help
[URL=http://se rver5.pict iger.com/i mg/433318/ other/heli x-coil.php][IMG]
Please help
[URL=http://se
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
RE: Helix Sheetmetal spring
2) Depends on what the feature is & how it is to be positioned.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
http:/
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
http://solidworks.carbonmade.com/
Solidworks 2006 SP4.0
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
see attached jpeg
[URL=ht
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
thanks for your help
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Tom Malinski
Sr Design Engineer
OKay Industries
New Britain CT
Your feature pattern should be pretty simple if you make a curve-driven pattern in the unfolded state.
I say this for two reasons;
1) Changing the K-factor or Bend Allowance doesn't alter the flat length. The flat length will always be the same as the length of the helix used to sweep the shape.
2) The wording used in the Help file is grammatically incorrect ... "Lofted bends use the K-Factor or Bend Allowance to calculate bends." would be correct. The "do" is superflous.
