Electrical Connector Grounding / Bonding to aluminum panels.
What are the typical requirements of a good electrical ground / bond to a metallic structure? Thank you.
RE: Electrical Connector Grounding / Bonding to aluminum panels.
William H. Bernhart, P.E.
Thank you for the responses. I could use the info on signal shielding since a cvable must be terminated to the structure. Thank you again.
