report setup in access 2000
once i setup the report and preview it the margins and page layout change back to the default of 1 inch margins and the layout is portrait.  what is going on?  thanks for your help
RE: report setup in access 2000
I have the same problem about margins too. Do you have some answare. Thanks for your help
camilovic@ptt.yu
The below is text from a newsgroup.
"Are you using A2K? There is a known issue with reports under this version of
Access losing the page setup, caused by the Name AutoCorrect feature. Either
disabling the feature (Tools|Options|General) or installing SR1/1a will also
cure the problem."
