Autocad drawing borders with polylines
Dear Folks;
I would like to import my customers Autocad drawing border and save it as a Solidworks drawing template. The drawing imports everything fine except for the border lines themselves. These are polylines and when you import them the width changes dramatically. I can find no way to edit the width back to normal from within solidworks. I dont relly want to mess with the customers border within autocad to replace the polylines unless I absolutely have to.
Does any one have any suggestions ?
Adrian Dunevein
www.aaadrafting.com
Adrian Dunevein
www.aaadrafting.com
RE: Autocad drawing borders with polylines
Hope that helps.
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
Bradley
File > Open (dwg option), the import wizard pops up.
Create new SW Drawing
--Convert to SW entities.
Next
I choose Model, not layout
If the width isn't correct, use the "Line Thickness" tool on the "Line Format" toolbar to thicken or thin the width.
You may have to clean it up a bit, such as center it on your sheet. Finally, save as template and sheet format in SW for future re-use.
Flores
SW06 SP4.1
