HEAT TRANSFER
HEAT TRANSFER
HEAT TRANSFER
I have 3-4" thick steel platens used in processing at temperatures of 450 -600F. The original cooling system becomes ineffective due to fouling / mineral build up when water is the working fluid.
How effective is cooling with air? What flow rates are needed?
RE: HEAT TRANSFER
Sounds like you're better off trying to find some sort of chemical to neutralize the scaling.  Cooling with air drops the heat transfer coefficient substantially.
TTFN
RE: HEAT TRANSFER
To kevinsnyder, are you using evaporative cooling ? Kindly describe in more detail.
